DSC Alarm
I need to know if exist the option to integrate DSC Alarm system into Logicmachine control using RS232 or IP protocols, I used Crestron integration in the past and it worked fine but I prefer integrate directly to KNX using Logic Machine if it is possible, THX
I know only Paradox alarms systems integration on KNX with Poland firm TOKKA gateway
http://www.tokka.pl/offer.html
Please let us know if DSC alarm panel integration with LM5 available. Has anyone done the integration already?
Regards
Hima
DSC has a closed protocol, but I think it is based on RS485. May be somebody can play with it - try to connect directly to it's BUS. Also I know that only Poland panel Satel has module for KNX integration... Sad I spoke with LM developers, they have something like "LM security" device.. But approx. price was very big for me. What do you think - can be interesting for community security panel integrated with LM? What interfaces do you need? I with pleasure can test such a prototype and give my recommendations/advises.. (My main job - service engineer, configuring different security/access systems.. What I see - it can be device with 4-8 inputs, max 4 areas, some DO, DI, LAN and interfaces.. Zone types can be made as a scripts... Any ideas??
Just FYI: Inim (italian) has KNX module also for their smartliving - I am currently working with it to get it installed.
It supports partition on/off, zone info(motion), ... The module is very pricey... but once you have it running it allows for triggering based on home, not at home, asleep - if you like us always put on the alarm.
http://www.inim.biz/prodotto.php?node=341&lang=en
[/url]
[url=http://www.inim.biz/prodotto.php?node=341&lang=en]
INIM also has ModBUS possibility.
