Threads: 31
Which HW version do you use? You can always do esf import.
Threads: 2
HW: Wiser for KNX (i.MX6)
SW: 2.6.2
When I finished designing in ETS, I found out that I cannot import the project, I lost a lot of time to find the reason. I wonder why this particular device is causing the problem.
I solved it like this: I create a temporary new project and only copy group addresses to it, and such a lean project (without devices) can be imported. It's a bit of a hassle.
Threads: 31
HW version is on the side label. Just check how much Total System memory you have. It is System Status.
Threads: 2
V3.1
Total system memory 249.0M
Used 16.9M (7%)
Free 232.1M (93%)
Buffered 7.3M
Cached 11.0M
Threads: 31
OK, this is a surprise, how big is he project?
Threads: 2
When I was looking for the reason, I noticed that it is enough to add only this device to the naked project and the project cannot be imported anymore.
Threads: 31
If you can send to pm your project and we will look in to it.
This is due to a large device description file in the project which causes browser tab crash. This only affects Chrome/Edge but not Firefox. A work-around fix will be implemented in the next firmware.
