Link Object not showing anymore
I don't know why, but the link objects do not appear anymore in visualization (plans and layouts) but appear on editing ! (see attachment)
I don't know what happened, because the were working fine !
Thank you
Does this link actually exists? If not then this is correct behavior.
(07.04.2022, 09:48)Daniel Wrote: Does this link actually exists? If not then this is correct behavior.
Yes, the link exists, and the navigation link works fine in editor !
I have noticed one strange behaviour, that could be causing this.
When I add a new completely blank plan, it generates a new plan #ID, but when I try to access the direct link to the plan, it shows another plans that it is not related !
Blank plans are not rendered in the viewer. So links might disappear due to this.
Just add some object to this plan and all will be fine.
(07.04.2022, 10:15)admin Wrote: Blank plans are not rendered in the viewer. So links might disappear due to this.
OK, that was the problem, I added a temp text label to the pages and now seems to be showing correctly.
Thank you
