Animate .svg immage - problem with page refresh
Hi guys, I need help again Big Grin
I have an .svg icon for the allarm that blink and I put it into a page. This icon will be visible only when the value of his related object is between 4 and 7.
If I open the visualization when the value of the object is already between 4 and 7 there are no problems (the icon blink), but if it reachs these values after the page opening, the icon is freezed and does't blink until I manually refresh the page..
Do you know why this is happening? and how to resolve it?
Thank you!
Edit: This problem doesn't happen when I'm in the "visualization" tab (the tab where I can modify pages)
Is the default icon also SVG? Which browser are you using?
(22.09.2016, 17:03)admin Wrote: Is the default icon also SVG? Which browser are you using?
Yes all my icons are .svg immages and I use Firefox. I just tryed to use Chrome and it works perfectly! Big Grin
With Microsoft Edge and IE it does't work.. After some research I think that it is a browser problem, although firefox should be fully compatible..
Thank you, Admin!
Yes, it's a bug in Firefox. SVG animation works correctly in Nightly build 52, so it should be fine in stable version pretty soon.
(23.09.2016, 06:39)admin Wrote: Yes, it's a bug in Firefox. SVG animation works correctly in Nightly build 52, so it should be fine in stable version pretty soon.
Great news! Thank you! Big Grin
