High CPU Load
Hello
I have a high CPU Load. I look at the commands in processes app and there is a command KNX backend which loading the SL
What could be the issue.
Check KNX TP and IP load. You might have a loop somewhere which causes a lot of traffic.
Thanks Admin
Here is the knx statistics screen shot.
I have IP Routers
also I have two SL but they are not connected to the same TP
Do you have KNX/IP filtering enabled? Maybe there are many message on the IP backbone? If messages are filtered they won't appear in the statistics but might cause high CPU load.
Disable KNX/IP features and check if the load is still high. Then you can switch from KNX/TP to IP mode temporarily to check if KNX/TP is at fault.
