Threads: 52
Can HL and SL write KNX telegramms with secure ?
How can I upload the secure code ? By import KNXproj or I must put it on the System Page (KNX connection )? In this last case, where I found the 32 hexadecimals code ?
Alberto
KNX Advanced Partner + Tutor
At this moment only secure Routing (multicast) is supported. Backbone key can be found in ETS > Reports > Project Security. You can export report to PDF to be able to copy/paste the key. The option to automatically extract this key when importing the project file will be added later.
Threads: 31
Good question, probably KNX.org should answer this. If you go to Panels-All panels- Reports then it should be there under Security but can't find it.
Threads: 31
Which version of ETS is it?
Threads: 8
I have 6.2.2.7302 at the moment
Threads: 8
I noticed the issue also when trying to reproduce, just upgraded to 6.3.0 and now it shows it again...
