Threads: 2
I want to control RGBW 6 byte (251.600) with Mosaic. Is it possible to do or do I need to split the 6 byte group into individual colour groups and then back again? If that is the case, does anyone have a script that does this?
Threads: 35
Yes at this moment of time we don't have widget for the 6byte
Threads: 35
We just added new widgets in Mosaic for 4Byte and 6Byte RGBW.
Threads: 2
14.07.2022, 06:05
(This post was last modified: 14.07.2022, 06:44 by Jonasw .)
Thank you!
I updated mosaic to the new version, but I cant find the new widgets. Do I need to import them separately?
Update Mosaic again, new RGBW widgets should be there now.
Threads: 2
The customer wants pure white from the RGBW fixture, is there any possibility to do that with the 6-byte widget? I was expecting either #000000 and the slider maxed or #FF000000 to produce pure white, but both results in all colors maxed.
Threads: 35
4th byte is for white, does your light have dedicated white LED or only red/green/blue?
Threads: 35
Try 000000FF00
Threads: 2
05.09.2022, 08:39
(This post was last modified: 05.09.2022, 08:40 by Jonasw .)
That also seems to trigger the RGB-LEDs. See attatched status after #000000FF00 write.
Threads: 35
From Object view select this. Is this getting you white? Seems there is bug in Mosaic
Threads: 2
That makes pure white yes
We will add new RGBW widgets with a separate white control slider in the next Mosaic version.
New Mosaic version with split RGB/W control widgets has been published.
