Simple Staircase Timer
Hi.
I need help with a simple staircase timer script. Staircase with after dimming with two step.
When the trigger gets true 1/1/1, Timer 1 and Timer 2 starts and Set Value High to 1/1/2 Output.
After ten minutes the Set Value Low is set to 1/1/2 Output. If the time runs out it should write Set Value Off.
But every time the trigger recive true the timer 1 and 2 is retrigged.
If timer 2 is active and the trigger recive true it should set 90%.
1/1/1 Trigger Staircase 1bit
1/1/2 Output 1byte
Set Value High 90%
Set Value Low 20%
Set Value Off 0%
Set Timer 1 = 10min
Set Timer 2 = 20min
Br
Resident script with 0 sleep time. Adjust timers table as needed. This script can handle multiple timers.
if not client then
  timers = {
    ['1/1/1'] = {
      output = '1/1/2', -- dimmer control (0..100%)
      onvaluehigh = 90, -- high output value in %
      onvaluelow = 20, -- low output value in %
      timeouthigh = 10 * 60, -- time to keep high value (in seconds)
      timeoutlow = 10 * 60, -- time to keep low value (in seconds)
  function timersetstate(timer, state)
    grp.checkwrite(timer.output, timer['onvalue' .. state] or 0)
    timer.state = state
    timer.ticks = timer['timeout' .. state]
  function timertimeout(timer)
    local state = timer.state == 'high' and 'low' or 'off'
  for _, timer in ipairs(timers) do
    timer.state = 'off'
  grp.sender = 'tm'
  client = require('localbus').new(0.1)
  client:sethandler('groupwrite', function(event)
    local timer = timers[ event.dst ]
    if timer and event.sender ~= grp.sender then
      local value = tonumber(event.datahex, 16) or 0
      if value == 1 then
        timersetstate(timer, 'high')
  end)
client:loop(1)
for _, timer in pairs(timers) do
  if timer.ticks then
    timer.ticks = timer.ticks - 1
    if timer.ticks == 0 then
      timertimeout(timer)
Thank you very much for the help.
Hi again.
Is it possible to have a slave input to retrigger the timer when it is active?
1/1/2 Output 1byte
1/1/3 Slave Input
Set Value High 90%
Set Value Low 20%
Set Value Off 0%
Set Timer 1 = 10min
Set Timer 2 = 20min
if i only want the staircase timer to send 90% when its trigged, and the time is out it send 10%
Remove timeoutlow and the timer won't go into off state.
timers = {
  ['1/1/1'] = {
    onvaluelow = 10, -- low output value in %
