two area scrollable
I have a CBus Wiser SHAC, I would like to be able to have two scrollable areas on one page as show in attached image.
I can achieve this with 2 iframes however when I point the frames to specific pages on the SHac eg scada-vis/#105 It displays the page ok, but appears to load the entire visual into the iframe.
Is there a way around this ?
Use these settings in Utilities > Vis. configuration:
Im trying to do phone scrollable page but I can´t. In PC it works but in movile phone it doesn´t scroll
In the other hand, I put a background in layout and it scroll with the page. How can I scroll page with layout fixed size?
Thanks!
Which OS/Browser are you using? I've tried Firefox and Chrome on Android and Safari on iOS - all work fine.
(14.09.2022, 09:37)admin Wrote: Which OS/Browser are you using? I've tried Firefox and Chrome on Android and Safari on iOS - all work fine.
I´m using chrome.
I can see that when I try to scroll by clicking on a button, image... of the page or if the layout has a background image, it does not scroll. If it is empty and I click on the background of the page if it scrolls
(05.09.2022, 06:34)admin Wrote: Use these settings in Utilities > Vis. configuration:
I don't want to do it with the stem generated menu, I want to create my own menu, and have it work like the docked menu.
This can be done via Custom JavaScript but we don't have a ready-made examples for this. Alternatively you can style the standard menu using CSS to suit your needs.
