Modbus TCP debug
Im wondring if its possible for Lm to debug incoming requests from master.
i know about the "mbConfusedetdebug".
I managed to get this when using mb:readregister(x) in combination with mb:debug | * string: [00][01][00][00][00][06][FF][03][00][02][00][01] |
This is excatly what i want , but i need to recieve it when an external master sends a request, not the Lm trying to read or write.
I wan't to be able to debug the request so i can use the data later in the code for mapping different settings.
-Marcus
This example will create Modbus TCP slave on port 502. It will log all requests/responses.
123456789101112131415161718192021
require('luamodbus') mb = luamodbus.tcp() mb:open('0.0.0.0', 502) mb:setmapping(0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF) debug = {} mb:setdebug(function(ch)   debug[ #debug + 1 ] = ch end) while true do   mb:handleslave()   if #debug > 0 then     log(table.concat(debug))     debug = {}   end end
