13.09.2022, 14:01
I'm working with a Schneider Clipsal CBUS SHAC where the Group Address range 0/250/xxx is defined as the 'User Parameter application.
This range of group addresses can have objects with data types of String, Boolean, Integers, Dates, Strings etc.
And while I can create a second 'User Parameter 2' application at 0/48-127/0-254 for example, these custom application ranges only seem to support numeric values (0-254).
I assume this is particular to the Schneider Clipsal CBUS units.
Is there away of creating a second 'User Parameter 2' application at 0/48-127/0-254 which supports String, Boolean, Integers, Dates, Strings etc (the same as the existing User Parameter group at 0/250/0-254)
Kind Regards
James
Kind Regards
James
