Threads: 7
12.10.2016, 17:56
(This post was last modified: 12.10.2016, 18:21 by Erwin van der Zwart.)
I don't think this data is available on the SIM itself.
Normaly you send sms to provider and you reveive the
value back by SMS.
It is possible to receive this reply sms and gsub the data from the received string.
You have to check out what string you need to send to , and what number to use for, your provider to receive the reply.
If you know those 2 items it's easy to create your wish.
Sorry, i see now that you already receive the SMS with the reply.
You can fetch the saldo from the received string by using:
amount = receiveddata:match("stringbeforedatapart(.-)stringafterdatapart")
Threads: 71
you can specify how to do it?
in SmsHander, I need to add this code somewhere. and what to do next.
I'm new employees, should also have little trouble.
thank you very much!
Threads: 7
The pop-up is simple, just use inside the handler code i posted the
command alert('current sim value is: ' .. amount)
The other question is harder, as you want to dail a number to request
the reply SMS. i never tried that before, maybe admin has script for that.
I would check if you can send SMS to request the value reply, if your provider support that
then you can use current sms script to send the request.
Threads: 71
06.08.2017, 11:17
(This post was last modified: 06.08.2017, 11:19 by phongvucba.)
Please help me! I have some problems.
I see ! When a message arrives (as shown below)
I want to retrieve the message sequence, what should I do?
The purpose is to take that string, to control something (control the lights by SMS).
Can someone help me?
Thank all!
