Script run
Hi everybody!
Is there a command to run a script? I have found only enable/disable commands(
What exactly do you want to do? If you have some common code that you need to run from different scripts you can wrap it into a function and place it into Common functions or a User library.
Lets say I have time based script, which starts every 30 minutes. I need to call it from event based script.
Then do as I suggested: wrap your code into a function and place it into Common functions or a User library. Then call this function from both scheduled and event scripts.
Thank you, will do that.
