Bacnet export to EDE
Is it possible to export Bacnet-objects from Logic Machine 5 to an EDE-file directly?
Found the export to .csv, but can`t find export to EDE.
This is not implemented, You can use Yabe to export to EDE
(26.09.2022, 08:52)Daniel Wrote: This is not implemented, You can use Yabe to export to EDE
My LM5 is converting many objects to the BACnet,  and I need to export only the alarm objects to EDE, is there any solution for that?
EDE is a text/csv format. You can edit it manually and remove unneeded entries.
(29.09.2022, 12:03)admin Wrote: EDE is a text/csv format. You can edit it manually and remove unneeded entries.
Thanks a lot
