MySQL Server Connection Problem
We installed all the packages , we read all the forum but we failed to connect our LM to a MySQL Server Database. can you hep us for this questions ?
1-) What is the version of Mysql Library package installed in LM ? We need to check with our Server version compatibility ?
2-) Can you make a suggestion for MySQL version for Windows ? Also can you make a suggestion for which port will be open in windows etc.
Regards,
What kind of error are you getting? MySQL uses port 3306/TCP by default. Exact version should not matter.
mysql LUA Library depends on your LM hardware
https://dl.openrb.com/lm-21-imx6/pkg/
here you can find MX6 platform extra package to install on you LM
you can use whatever version you like, it will connect if the library is fine.... I'm running mariaDB 10.3.36 and it works fine
Remember to create a specific user with specific rights Wink
