LogicMachine5 Reactor IO
LogicMachine5 Reactor IO is all-in-one cross-standard controller uniting in one device gateway functionality, cloud service integration, complex network logic engine, easy-to create visualization platform, IP Router, I/Os and much more.
Hightlights:
  • 24 I/O ports
  • LM5 Reactor IO has built-in KNX TP1, EnOcean bi-directional interface (optional), two serial interfaces
  • Power-over-Ethernet powering
  • Application development and application store
  • Cloud ready device with Microsoft Azure, Amazon Web Services and other services supported
  • Gateway and uniform way of control of KNX, ModBus RTU/TCP, BACnet IP, EnOcean (optional), DMX, M-Bus, GSM and more
  • Unlimited scenario and logic engine
  • Unlimited visualization platform for PC and for touch devices
  • Size: 6 DIN units
  • Remote KNX bus control and KNX device reprogramming
  • Object logging with trends support and data exporting to external servers
  • Optional 3x more powerful CPU than all previous LogicMachine versions
[Image: LM5RIOE_R_EMBS_v1.1-300x237.png]
See here i.MX28 (CPU of LM2, LM3, LM4) and i.MX6 (optional 3x speed CPU for LM5 series devices) comparison tests: http://openrb.com/imx28-vs-imx6-cpu-test...icmachine/
Here is more information on LM5 Reactor IO: http://openrb.com/logicmachine5-reactor-io/
LM comparison table: http://openrb.com/wp-content/uploads/201...0.2016.pdf
Hi, is there a new firm available for this team?
Newer from this?
https://forum.logicmachine.net/showthread.php?tid=2313
(05.05.2020, 10:15)Daniel. Wrote: Newer from this?
which firmware corresponds to it? I have tried to install several and they give me an error.
This firm loads it but I lose outputs in the configuration
LM5 Power Reactor IO: https://dl.openrb.com/lm-19-imx6/lm5ra-20191015.img
This is the fw, did you clear the cache ?
Try this FW: https://dl.openrb.com/lm-19-imx6/lm5m3ex-20191015.img
(05.05.2020, 10:42)admin Wrote: Try this FW: https://dl.openrb.com/lm-19-imx6/lm5m3ex-20191015.img
Hello, I would like to update the firm again. Can you confirm which one I should use on this device? Thanks
This one: https://dl.openrb.com/lm-21-imx6/lm5m3ex-20211014.img
