Threads: 8
22.10.2016, 16:20
(This post was last modified: 22.10.2016, 16:42 by Erwin van der Zwart.)
Hi Thomas,
I have seen this once before after setting the time in the future and setting it back after a while.
If that occurs there will be data written in the trend 'future' time, and the trend will only show new data again after that moment.
Did you do something with your time settings?
Threads: 3
Hi Thomas,
Did you try to force refresh the page cache? or try with another browser?
On windows, Ctrl+F5 should do the trick. on Apple cmd+r.
Threads: 32
The same happened to me and it has already happened twice in the last month.
The first time it happened in all the trends, I returned to create the trends and it worked for 2 or 3 days and it happened again, in all the trends except for 1.
Anyone can help me??
Threads: 35
Can you make a reboot and see what happened wit trends?
Threads: 32
11.10.2018, 11:04
(This post was last modified: 11.10.2018, 11:06 by DGrandes.)
I've done that and it's still the same
Threads: 35
Do you mean that you didn't lost any data and all is OK ?
Threads: 32
No, what I want to say is that I still do not see the trends logs. It still does not work
Threads: 35
Can you create new trend, leave it for few hours and reboot again?
Threads: 32
Good morning,
I have done as you said, I leave it along weekend and I have restarted to see what happened.
The new trends work well, but the others don´t work.
Threads: 35
It looks like you had bad luck and while LM was saving trends you had power shortage and the old trend files got corrupted. We will look in to it if we can improve it somehow. The only way is to delete the old ones and create new one, sorry for that.
Threads: 32
Ok, thanks.
Is there any way to backup only trends? Not the whole LM Backup.
Threads: 35
you can export them to other format but backup which you can restore is only full one.
Threads: 1
Hi there,
I need to modify the resolution time of around 200 trendlogs, is there a way to execute the modification for a large number but not all trendlogs i.e. those with categories C1 to C50 but not other categories?
Thank you
I assume you want to change "Resolution data" and "Daily data" parameters because resolution cannot be changed once trend log is created. Do all trends you want to modify have the same data retention parameters? And is the new parameter the same for all trends?
