Log 250 byte string to ftp file
Hi.
I want to log 250 byte string to ftp file.
And i also want to know how to calculate the time differrence of two 250 byte string.
See picture.
Br
MR
There are many CSV/FTP examples on the forum. There's also example on our website: https://openrb.com/example-export-last-h...-from-lm2/
As for the difference calculation it should be done on numeric values not on the strings that are formatted using the numeric values. Then you can simply subtract one value from another.
Okej, then i look it up.
If i understand it right about the difference.
Then i should compare the values before i convert it to string?
My script is done to log "on" value 1/1/1 and then add it to total value 1/1/2.
Total value shows "on" time in: year, month, week, days, h, m, s.
Br
MR
Any calculations should be done on numeric values. If you have date/time string you will to convert it back to a number before doing any calculations.
I don´t know how to convert it to numeric.
Could you help me with this?
Please describe exactly what do you want to compare and post the code that you use. Most likely you already have a numeric value before it's converted to a formatted string that is written to 250 byte object.
I use this script.
I have four timers an i want to compare two.
Total time 7/0/4 and 7/0/14.
----------Timer for group 7/0/1 ---------------
value = event.getvalue()
key_now_1 = 'ontime_now_1'
out_now_1 = '1/0/2'
key_last_1 = 'ontime_last_1'
out_last_1 = '1/0/3'
key_total_1 = 'ontime_total_1'
out_total_1 = '1/0/4'
time = storage.get(key_now_1)
now = os.time()
if value then
  if not time then
    storage.set(key_now_1, now)
    formattime(out_now_1, 0)
    storage.set(key_last_1, now)
    formattime(out_last_1, 0)
  if time then
    time_total = storage.exec('incrby', key_total_1, now - time)
    formattime(out_total_1, time_total)
    storage.delete(key_now_1)
    storage.delete(key_last_1)
  grp.update(out_now_1, '')
----------Resident Script---------Timer for group 7/0/1 ---------------
out_now_1 = '1/0/2'
time_now = storage.get(key_now_1)
time_now_1 = storage.get(key_last_1)
if time_now then
  time_now = os.time() - time_now
  formattime(out_now_1, time_now)
  formattime(out_last_1, time_now)
  time_total = storage.get(key_total_1, 0)
  formattime(out_total_1, time_total + time_now)
-----------------Common Function----------------------------
function formattime(output, seconds)
  local minutes = math.floor(seconds / 60)
  local hours = math.floor(minutes / 60)
  local days = math.floor(hours / 24)
  local res = {}
  seconds = seconds % 60
  minutes = minutes % 60
  hours = hours % 24
  if days > 0 then
    res[ #res + 1 ] = days .. 'd'
  if hours > 0 then
    res[ #res + 1 ] = hours .. 'h'
  if minutes > 0 then
    res[ #res + 1 ] = minutes .. 'm'
  if seconds > 0 or #res == 0 then
    res[ #res + 1 ] = seconds .. 's'
  res = table.concat(res, ' ')
  grp.update(output, res)
Modify storage keys and output address as needed:
key_total_2 = 'ontime_total_2'
output = '1/2/3'
value_1 = storage.get(key_total_1, 0)
value_2 = storage.get(key_total_2, 0)
delta = math.abs(value_1 - value_2)
formattime(output, delta)
Thanks alot for the help.
Br
MR
