This script will fetch the daily prices from the ENTSO-E Transparency platform for your country.
It will also give the average price of the day, percentages based on the lowest and highest price for all prices of the day and the group address of the lowest and highest price object, so the lowest price is 0% while the highest price is 100%. A value of 34% means you will pay 34% more than what is possible on another time of the day.
Apart from this daily data, you can do a trend log on the average price, which can then be processed monthly to get a monthly average, along with your consumption tracking you are able to calculate a more precise price per kWh, certainly if your country makes use of some sort of 'capacity tariff'.
All useable values e.g. prices, percentages, objects group addresses of lowest and highest price and average, are stored in virtual objects for use in other scripts.
For prices, 24 objects are needed, for the percentages 24 objects are needed, and 3 objects for lowest, highest and average
Visual of objects
Prerequisites
Variables
Thanks and gratitude to all the people that inspired me and where I used code from!
Feel free to optimise and extend!
Visual of objects
Prerequisites
- You must register a free account on the ENTSO-E Transparency Platform and request a personal API key
- Scheduled Script at 0 minute, 14 hours, daily, every day, every month
- The way (virtual) objects for price and percentage are numbered gives you the advantage to see the hours based on the group address, see further
- The first object for storing the prices must start with 0 (eg.: 34/1/0 or 32/3/0,...)
So object 32/1/4 represents the price for hour 04:00, 32/1/20 the price for hour 20:00
Prices are in €/MWh
14.4 byte floating point
- The first object for storing the percentages must start with 0 (eg.: 34/1/0 or 32/3/0,...)
So object 33/1/4 represents the percentage for hour 04:00, 33/1/20 the percentage for hour 20:00
- The objects for lowest, highest and average price are 14.4 byte floating point
Prices are in €/MWh
- The object for lowest and highest groupaddress must be 16.14 byte ASCII string
Variables
- fetchfortommorow: default TRUE, normally prices are fetched for tommorow making it more useable, but if you want to fetch prices for today set this to FALSE
- SecurityTokenAPI: your personal API security token that you can request by making a free account on the ENTSOE-E Transparency Platform and by sending an email to them.
- EntsoeDomain: the string to be used for your country, you can find it here in this API manual
- StartGrpAddr: The 2 first numbers of the objects to be used for prices including seperation symbol, eg: 34/2 or 32/1
- StartGrpAddrPercent: The 2 first numbers of the objects to be used for percentages including seperation symbol, eg: 34/2 or 32/1
- SecondsPastTillRefetch: Safety swith to prevent to much polling if cron job is misconfigured (prevents you from being blocked on the platform) Default is 39600 seconds, being 11 hours
- StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes: Prevents polling data when it's not possible. Since prices for the day ahead are published at 13:00 hours the current day, it's no use to run this script outside certain hours.
- objaddrCheckUpdateTime: Object used to check the last update time, default the second price object being x/1/1
- objaddrLowestprice: Object used to store lowest price
- objaddrHighestprice: Object used to store highest price
- PrintLOG: Default FALSE, set TRUE for troubleshooting
local fetchfortommorow = true -- true for tommorow, false for today
local SecurityTokenAPI = 'your-personal-key' -- your personal security token, get it at entsoe transparency platform
local EntsoeDomain = '10YBE----------2' -- find your domain for the country you are living at https://transparency.entsoe.eu/content/static_content/Static%20content/web%20api/Guide.html#_load_domain
local StartGrpAddr = '34/1' -- group addresses used to store the €/MWh prices per hour, x/x/0 is 00:00 hour, x/x/1 is 01:00 hour
local StartGrpAddrPercent = '34/2' -- group addresses to store calculated pecentages for the hours, x/x/0 is 00:00 hour
local SecondsPastTillRefetch = 39600 -- seconds that must be past till new refetch will be done, default 39600 seconds, is 11 hours
local StartTimeHours=13 -- start time in which fetching is allowed, used in function IsTimeBetween
local StartTimeMinutes=00 -- start minutes in which fetching is allowed, used in function IsTimeBetween
local StopTimeHours=23 -- stop time in which fetching is allowed, used in function IsTimeBetween
local StopTimeMinutes=59 -- stop minutes in which fetching is allowed, used in function IsTimeBetween
local objaddrCheckUpdateTime = '34/1/1' -- object to check last updated date from
local objaddrLowestprice = '34/1/26' -- object to store groupaddress of lowest price of the day
local objaddrHighestprice = '34/1/27' -- object to store groupaddress of highest price of the day
local PrintLOG = false -- logging
-- https://stackoverflow.com/questions/35402992/how-to-check-if-current-time-is-between-two-others
-- Function to check if current time is between 2 other defined times
-- Returns true if time is between 2 other times
local function getMinutes(hours, minutes)
return (hours*60)+minutes
local function IsTimeBetween(StartH, StartM, StopH, StopM, TestH, TestM)
if (StopH < StartH) then -- add 24 hours if endhours < starthours
local StopHOrg=StopH
StopH = StopH + 24
if (TestH <= StopHOrg) then -- if endhours has increased the currenthour should also increase
TestH = TestH + 24
local StartTVal = getMinutes(StartH, StartM)
local StopTVal = getMinutes(StopH, StopM)
local curTVal = getMinutes(TestH, TestM)
return (curTVal >= StartTVal and curTVal <= StopTVal)
local function IsNowBetween(StartH,StartM,StopH,StopM)
local time = os.date("*t")
if PrintLOG then
log(time.hour, time.min) --check if time is correct, if not change to os.date("!*t") for UTC time
return IsTimeBetween(StartH, StartM, StopH, StopM, time.hour, time.min)
if PrintLOG then
log(IsNowBetween(StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes))
objectupdatedate = (grp.find(objaddrCheckUpdateTime).updatetime) -- get update date for chosen object
diff = os.difftime(os.time(),objectupdatedate) -- difference between current time and objectupdatetime in seconds
if diff > SecondsPastTillRefetch then --check if last run was more than x seconds ago https://www.google.com/search?q=seconds+to+hours
if PrintLOG then
log('more than '..SecondsPastTillRefetch..' seconds since last run')
if (IsNowBetween(StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes)) then --check if current time is between hours that data can be fetched
if PrintLOG then
log('data can be fetched')
-- https://forum.logicmachine.net/showthread.php?tid=4268&highlight=entsoe
if fetchfortommorow then
date = os.date('%Y%m%d', os.time() + 86400) -- date is tommorow, default setting
date = os.date('%Y%m%d') --date is today
periodstart = date .. '0000'
periodend = date .. '2300'
log(date)
url = 'https://web-api.tp.entsoe.eu/api?securityToken='..SecurityTokenAPI..'&' ..
'documentType=A44&in_Domain='..EntsoeDomain..'&out_Domain='..EntsoeDomain..
'&periodStart=' .. periodstart .. '&periodEnd=' .. periodend
data, code = require('socket.http').request(url)
if not data or code ~= 200 then
log('request failed', data, code)
return
prices = {}
key = 0
callbacks = {
StartElement = function(p, tag)
if tag == 'TimeSeries' then
key = key + 1
prices[ key ] = {}
elseif tag == 'position' then
state = 'position'
elseif tag == 'price.amount' then
state = 'price'
end,
EndElement = function(p, tag)
state = nil
end,
CharacterData = function(p, value)
value = value:trim()
if #value > 0 then
if state == 'position' then
position = tonumber(value)
elseif state == 'price' then
prices[ key ][ position ] = tonumber(value)
parser = require('lxp').new(callbacks)
parser:parse(data)
parser:close()
if key > 0 then
for i, price in pairs(prices[ 1 ]) do
j = i - 1 -- shifts the first key from 1 to 0, so the first groupaddress is x/x/0 for 00:00 hour, next is x/x/1 for 01:00 hour,etc...
grp.checkupdate(StartGrpAddr..'/' .. j, price) -- update objects with newest prices
--log('uur ' ..j..' prijs: ' ..price)
-- https://stackoverflow.com/questions/69359710/how-to-get-the-smallest-number-in-a-table-with-lua
lowestprice = math.min(unpack(prices[ 1 ])) --lowest number in table
highestprice = math.max(unpack(prices[ 1 ])) --highest number in table
-- https://stackoverflow.com/questions/25835591/how-to-calculate-percentage-between-the-range-of-two-values-a-third-value-is
--input = grp.getvalue('34/1/13')
j = i - 1
percentage = ((price - lowestprice) * 100) / (highestprice - lowestprice)
--log('at hour '..j..':00 price is '..math.floor(percentage)..'% higher than lowest price today')
grp.checkupdate(StartGrpAddrPercent..'/' .. j, percentage) --update objects with newest percentages
if lowestprice == price then
grp.checkupdate(objaddrLowestprice, StartGrpAddr..'/' .. j)
if highestprice == price then
grp.checkupdate(objaddrHighestprice, StartGrpAddr..'/' .. j)
-- https://www.codegrepper.com/code-examples/lua/lua+calculate+average+number
function math.average(t)
local sum = 0
for _,v in pairs(t) do -- Get the sum of all numbers in t
sum = sum + v
return sum / #t
grp.checkupdate('34/1/25', math.average((prices[ 1 ])))
if PrintLOG then
log('data cannot be fetched yet')
if PrintLOG then
log('data has already been fetched and updated, not necessary to re-fetch data')
endThanks and gratitude to all the people that inspired me and where I used code from!
