Timedependent output from string
After a lot of help from Admin, im ended up with this piece of code:
url = 'https://api.energidataservice.dk/dataset/Elspotprices?offset=0&filter=%7B%22PriceArea%22:%22dk1%22%7D&sort=HourDK%20DESC&timezone=dk&limit=24'
resp = require('ssl.https').request(url)
data = require('json').decode(resp).records
max = 0        --nulstiller max værdi
min = math.huge        --nulstiller min værdi med uendeligt stort tal
sum = 0        --nulstiller sum værdi
        --Skriver time:minutter i "tid".
        -- %a    abbreviated weekday name (e.g., Wed)
        -- %A    full weekday name (e.g., Wednesday)
        -- %b    abbreviated month name (e.g., Sep)
        -- %B    full month name (e.g., September)
        -- %c    date and time (e.g., 09/16/98 23:48:10)
        -- %d    day of the month (16) [01-31]
        -- %H    hour, using a 24-hour clock (23) [00-23]
        -- %I    hour, using a 12-hour clock (11) [01-12]
        -- %M    minute (48) [00-59]
        -- %m    month (09) [01-12]
        -- %p    either "am" or "pm" (pm)
        -- %S    second (10) [00-61]
        -- %w    weekday (3) [0-6 = Sunday-Saturday]
        -- %x    date (e.g., 09/16/98)
        -- %X    time (e.g., 23:48:10)
        -- %Y    full year (1998)
        -- %y    two-digit year (98) [00-99]
        -- %%    the character `%´
tidtimer = os.date("%H")
tidminutter = os.date("%M")
for i, item in ipairs(data) do
  price = item.SpotPriceDKK/1000        --tildeler ordet price værdien af feltet SpotPriceDKK og deler med 1000 for at gå fra GW til KW.
  max = math.max(max, price)
  min = math.min(min, price)
  sum = sum + price
  grp.checkupdate('13/4/' ..i, price)
  item.hour = tonumber(item.HourDK:match('T(%d+)'))
--Gemmer prisen fra igår i datalager under Spotpris1...23
if tidtimer == 00 and tidminutter == 00 then
  storage.set('Spotpris' ..i, price)
avg = sum / #data
grp.checkupdate('13/4/25', avg)
grp.checkupdate('13/4/26', max)
grp.checkupdate('13/4/27', min)
table.sort(data, function(a, b)
  return a.SpotPriceDKK < b.SpotPriceDKK
end)
list = {}
for i = 1, 4 do
  item = data[ i ]
  list[ #list + 1 ] = string.format('%d = %.2f', item.hour, item.SpotPriceDKK)
hours = table.concat(list, '; ')
grp.checkupdate('13/4/28', hours)
-- viser angivede enheder i loggen
--log(avg, max, min, tidtimer, tidminutter, hours)
The code returns a 250 byte string at groupe address 13/4/28. Now i would like the script, or potentioaly a new script, to turn on a boolean group address at the specific timestamps from the groupe 13/4/28.
Eg. the script returns: string: 1 = 1523.93; 0 = 1559.11; 3 = 1559.93; 4 = 1561.04 wich means that i the hour between 01:00-01:59 is the cheapest hour, and so on.
When the electricity is cheap i want the script to set an output Smile
Hope everything makes sense Tongue
Modify the script that fetches the prices so it saves the list of cheapest hours into storage:
list = {}
price_hours = {}
for i = 1, 4 do
  item = data[ i ]
  list[ i ] = string.format('%d = %.2f', item.hour, item.SpotPriceDKK)
  price_hours[ i ] = item.hour
storage.set('price_hours', price_hours)
Then create a scheduled script that runs every hour at 0 minutes:
currhour = os.date('*t').hour
hours = storage.get('price_hours', {})
found = false
for _, hour in ipairs(hours) do
  if currhour == hour then
    found = true
grp.checkwrite('1/1/1', found)
