Sending Backup file to a chat_id in Telegram
Hi everyone!
I hope you can help me,
I would like implement a telegram group, where several logicmachine are sending every week two messages:
1-. A report with the info of mem, proc and sys resources along the week ==> no problem with that, using the CSV sending script available in this forum is easy
2-. The backupfile, in this case I tried to make a "puzzle" with several script .... but ... with no success!! I can not find nor the info or a good way to do it. Some one can guide me?
There is a function "sendDocument" in the telegram API but no idea how to use it to add the backup file.
Thanks a lot in advance!!!
Kike
You can install 2022 RC1 firmware and use webrequest library to create a backup: https://forum.logicmachine.net/showthread.php?tid=4425
Then send it using sendDocument by modifying this example: https://forum.logicmachine.net/showthrea...4#pid17944
(05.12.2022, 13:37)admin Wrote: You can install 2022 RC1 firmware and use webrequest library to create a backup: https://forum.logicmachine.net/showthread.php?tid=4425
Done! It works!
Thanks! I realized that the buckup structure is quite diferent as used to be, I undestand that everything related to the way to access the database did not change, did it?
Thanks!!!
There are no internal changes, just the backup format and backup directory/file layout.
(19.12.2022, 09:50)admin Wrote: There are no internal changes, just the backup format and backup directory/file layout.
Okie Dokie, One more question ...
I checked out that there is a new directory with the filter tables coded  in two files, ga_ip and ga_tp.
Is there a way to "edit" that files? via script of FTp ar any other methood?
I looked for this info in the database but I could not find anything
Thanks a lot!!!!
