Control Onkyo through tcp
Hi, I want to control an Onkyo device through TCP using eISCP.  The protol information can be seen here at section 1.2
https://tascam.com/downloads/tascam/790/...otocol.pdf
I found out some other code to control it using php
https://www.domoticz.com/wiki/Onkyo
or ruby
https://gist.github.com/also/3546825
I use this python code and it work perfectly from my computer
https://github.com/miracle2k/onkyo-eiscp
I try to make some code like below to power on the Onkyo from LM but it didnt work
cmd = 'ISCP\x00\x00\x00\x10\x00\x00\x00\x08\x01\x00\x00\x00!1PWR01\x0D'
require('socket')
sock=socket.tcp()
sock:settimeout(2)
a=sock:connect('192.168.1.100',60128)
b=sock:send(cmd)
Can you help me to make this code work? Thank you very much
The command looks correct. What do you get as a result for connect/send?
I Use
require('socket')
sock=socket.tcp()
sock:settimeout(2)
b=sock:send(cmd)
log(a)
log(b)
log('a = ' .. a)
log('b = '  .. b)
and get:
[Image: ylU4e6C.png]
Problem solve. Thank you
