Delay script
#21
(15.11.2023, 14:26)admin Wrote: Create user library named timers:
return function(timers)
  if not client then
    grp.sender = 'tm'
    function set(timer)
      grp.checkwrite(timer.output, timer.state == 'on')
      timer.state = nil
      timer.ticks = nil
    client = require('localbus').new(0.1)
    client:sethandler('groupwrite', function(event)
      local timer = timers[ event.dst ]
      if timer and event.sender ~= grp.sender then
        local value = tonumber(event.datahex, 16) or 0
        local state = value > 0 and 'on' or 'off'
        if timer.state ~= state then
          timer.state = state
          local ticks = timer['delay' .. state]
          if ticks > 0 then
            timer.ticks = ticks
            set(timer)
    end)
  client:loop(1)
  for _, timer in pairs(timers) do
    if timer.ticks then
      timer.ticks = timer.ticks - 1
      if timer.ticks == 0 then
        set(timer)
Resident script:
if not timers then
  timers = {
    ['1/1/1'] = {
      output = '1/1/2', -- binary output
      delayon = 10, -- on delay time (seconds)
      delayoff = 0, -- off delay time (seconds)
require('user.timers')(timers)
Hello, I will need a different version of the code above. When x1, x2, x3, ... all evaluate to true, it should again produce a single output 10 seconds later.
I would be very grateful if you could help, thank you.
Edit:  Hello, I think I've found the solution. I'm sharing it below.
if not timers then
  timers = {
    ['7/0/1' and '7/0/3' and '7/0/5'] = {
      output = '7/0/7', -- binary output
      delayon = 0, -- on delay time (seconds)
