Javascript mouse click event
How can I put a function when I click somewhere in the browser?
In the attachment there is an example
Do you have any visualization elements there or is it just blank space?
Side bands are blank space because I have set "Center plans, enable auto-sizing" in the Vis. configuration, but in the center of my page there are images, texts and objects
Something to start with Smile
CSS
.menu {   z-index: 1000; } .overlay-left {   position: absolute;   left: 0;   top: 0;   bottom: 0;   width: 200px;   background-color: red;   z-index: 999; } .overlay-right {   position: absolute;   right: 0;   top: 0;   bottom: 0;   width: 200px;   background-color: blue;   z-index: 999; }
JavaScript
$(function(){   var body = $(document.body), el;   // only apply script to user mode visualization   if (!body.hasClass('usermode')) {     return;   }   // create overlay element   el = $('<div></div>').addClass('overlay-left').appendTo(body);   el.on('vclick', function() {     alert('clicked left');   });   // create overlay element   el = $('<div></div>').addClass('overlay-right').appendTo(body);   el.on('vclick', function() {     alert('clicked right');   }); });
Thank you it works, but how can I adapt side bars? because this is the result
Try this, but it will only work correctly if all plans have the same width:
$(function(){   var body = $(document.body), leftEl, rightEl, timeout;   // only apply script to user mode visualization   if (!body.hasClass('usermode')) {     return;   }   // create overlay element   leftEl = $('<div></div>').addClass('overlay-left').appendTo(body);   leftEl.on('vclick', function() {     alert('clicked left');   });   // create overlay element   rightEl = $('<div></div>').addClass('overlay-right').appendTo(body);   rightEl.on('vclick', function() {     alert('clicked right');   });      function setSize() {     var rect = $('.layer.plan:visible').get(0).getBoundingClientRect()         , width = Math.ceil((body.width() - rect.width) / 2);          width = Math.max(0, width);     leftEl.css('width', width);     rightEl.css('width', width);   }      $(window).on('orientationchange resize', function() {     clearTimeout(timeout);     timeout = setTimeout(setSize, 150);   });      setSize(); });
Thank you!! Big Grin  It works perfectly! You are the best!
There's no sound anywhere in this script, can you explain what kind of sound are you getting?
