zigbee integration
I was wondering, we have a building with 20 rooms that have a master wall mounted old mechanical thermostat.
We would like to change this to
CTM https://ctmlyng.no/produkter/mtouch-one-alu-op/  or
Elko https://proff.elko.no/smart-super-termos...y2970.html
Do you have support for this in LM, i cant find them on list.
We would like to see room temperatur, change set point, heat on/off and calender on  locally them if possible so that they work stand alone in case of communication problems.
If not possible to adjust calender we can use calender in LM to change set point up and down
Do this sound like an solution to use LM as user visu to this?
These devices are not supported yet and they will require a profile to be added and maybe some other modifications in the ZigBee app for full support. Basic thermostat features like setpoint and operating mode are already supported in the app.
ok. So most likely we will get room temperature, setpoint and operating mode(eco\comfort etc?)
That will be ok in that case
Most likely, yes. But this needs to be tested.
