Read fire panel sensors current state
Hi. I have a fire panel and want to read the state of each sensor by RS232. I´m new at LUA but made some things like this:
-- Include library before calling serial functions
if not port then
require('serial')
-- Setting port parameters and open serial port
port = serial.open('/dev/RS232', {
baudrate = 19200,
databits = 8,
stopbits = 1,
parity = 'none',
duplex = 'full'
-- Flushes any read/unsent bytes
port:flush()
-- Read data from serial port
if port:read() == 'Powr___1'
-- Send alert when condition matched
then alert('Projector is ON')
-- Closing serial port
port:close()
¿How do I enter this contact ID event for reading the current state of the sensor in LUA command. Attached is the contact ID events codes.
¿Is there a "Hello world" command to see if the communication is established between LM and Fire panel?
Thanks for your help
Do you have documentation for the serial protocol?
(24.01.2023, 07:12)admin Wrote: Do you have documentation for the serial protocol?
Just this.
.pdf   3102351-EN R005 VS1 and VS4 Technical Referenc.pdf (Size: 4.77 MB / Downloads: 14)
Try running this script and see if you get anything in the Logs tab. Check that the panel is configured to send events to RS232.
if not port then   port = require('serial').open('/dev/RS232', {     baudrate = 19200,   })   buf = {}   function logbuf()     local txt = table.concat(buf)     log(txt)     buf = {}   end end char, err = port:read(1, 1) if char then   if char == '\r' or char == '\n' then     if #buf > 0 then       logbuf()     end   else     buf[ #buf + 1 ] = char     if #buf == 100 then       logbuf()     end   end end
