math.random() allways retuns 0.7942
I noticed that when I use the math.random() with out arguments returns allways the same value, if arguments are used return the maximun.
example:
log(math.random())
returns:
* number: 0.794206292431241
what I am doing wrong?
Thanks!!
See this: https://forum.logicmachine.net/showthread.php?tid=2052
(03.02.2023, 11:32)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=2052
Thanks! It works!
Can I have the math.random function output random numbers, letters, and special characters?
Use this. Modify the character list as needed.
function randompassword(length)   local characters = '0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz'   local max = #characters - 1   local buffer = {}   length = length or 12   local ts, tu = os.microtime()   math.randomseed(ts * 1e6 + tu)   for i = 1, length do     local rnd = math.random(1, max)     buffer[ i ] = characters:sub(rnd, rnd)   end   return table.concat(buffer) end length = 8 password = randompassword(length) log(password)
(03.06.2024, 06:40)admin Wrote: Use this. Modify the character list as needed.
thank you very much
