Threads: 1
07.02.2023, 23:57
(This post was last modified: 08.02.2023, 09:13 by coolaew.)
Hello!
Using a SE spaceLYnk I'm trying to send an image to a 2N IP Verso intercom when the firealarm is activated and remove the image when the fire alarm resets.
The intercom uses HTTPS and Digest authentication.
I've got it working in postman but not from the SpaceLYnk.
I only got the DELETE part working with basic authentication.
Code: -- /img/STOP_DNE_241x320.png (I want to use this)
-- /img/fire_241x320.png (Alternate image for testing)
fire = grp.getvalue('32/1/1')
--log(fire)
if fire == true then
log('FIREALARM ACTIVE')
-- Send image to intercom
-- https://10.0.0.230/api/display/image?display=ext1
elseif fire == false then
log('No fire')
-- Delete image from intercom
local https = require("ssl.https")
local ltn12 = require("ltn12")
local response_body = {}
local request_body = ""
local res, code, response_headers, status = https.request{
url = "https://test:test@10.0.0.230/api/display/image?display=ext1",
method = "DELETE",
source = ltn12.source.string(request_body),
sink = ltn12.sink.table(response_body),
protocol = "tlsv1_2"
if code == 200 then
log("Image deleted successfully!")
log("Error deleting image: "..code)
log('ERROR')
I found some threads here about digest authentication and image handling, but I'm not experienced with coding so I was not able to put the code together from what I found to do what I need.
I have saved the image to /img/ which i created in the root of the ftp server logged in as ftp.
Here's a link to the 2N API documentation, part 5.9.2 is about sending images and clearing the display.
https://wiki.2n.com/hip/hapi/latest/en
Try this. filedata variable must contain your image in JPEG format. Use io.readfile() to read a local file.
Code: require('ltn12')
require('ssl.https')
boundary = os.date('%d%m%Y%H%M%S')
filedata = '...' -- image data as a binary string
body = table.concat({
'--' .. boundary,
'Content-Disposition: form-data; name="blob-image"; filename="picture.jpeg"',
'Content-Type: image/jpeg',
filedata,
'--' .. boundary .. '--',
}, '\r\n')
resp = {}
res, code, response_headers, status = ssl.https.request({
url = 'https://test:test@10.0.0.230/api/display/image?display=ext1',
sink = ltn12.sink.table(resp),
method = 'PUT',
source = ltn12.source.string(body),
headers = {
['content-length'] = #body,
['content-type'] = 'multipart/form-data; boundary=' .. boundary
log(res, code, table.concat(resp))
For digest auth you can use this example: https://forum.logicmachine.net/showthrea...64#pid9364
Replace ssl.https.request in the above code with request from the digest code.
Threads: 1
I updated the filedata line
Code: filedata = 'io.readfile(/img/STOP_DNE_241x320.jpeg)' -- image data as a binary string
But I get this error now
Code: 08.02.2023 22:19:12
* arg: 1
* number: 1
* arg: 2
* number: 200
* arg: 3
* string: {
"success" : false,
"error" : {
"code" : 12,
"param" : "blob-image",
"description" : "invalid parameter value"
Threads: 8
You converted the whole command into a string by placing the '' at the wrong position ..
Try: filedata = io.readfile(‘/img/STOP_DNE_241x320.jpeg')
Threads: 1
09.02.2023, 05:26
(This post was last modified: 09.02.2023, 05:43 by coolaew.)
Ok, tried that now, new error.
Code: 09.02.2023 06:25:54
User script:19: invalid value (nil) at index 5 in table for 'concat'
stack traceback:
[C]: in function 'concat'
I'm suspecting that either the path to the file is wrong or there's a permission missing somewhere.
I've tried using /img/FILE and /data/ftp/img/FILE
Try this (assuming that you've uploaded the image to Vis. graphics > Image / backgrounds):
Code: filedata = io.readfile(‘/www/scada/resources/img/STOP_DNE_241x320.jpeg')
Threads: 1
Thanks! Finally got it working.
It might have been your suggestion, or it might have been my typo in the filename that fixed it... 241/214...
Now I just have to get digest auth working and I'm all set
Code: 09.02.2023 15:38:52
* arg: 1
* number: 1
* arg: 2
* number: 200
* arg: 3
* string: {
"success" : true
Threads: 1
Thank you so much!
Finally got it working with digest, it could problably be done prettier, but this works for me
Code: fire = grp.getvalue("32/1/1")
if fire == true then -- Uploads image to intercom
log("FIREALARM ACTIVE")
local skthttp = require("socket.http")
local skturl = require("socket.url")
local md5sum = require("encdec").md5
boundary = os.date("%d%m%Y%H%M%S")
filedata = io.readfile("/www/scada/resources/img/STOP_DNE_214x320.jpeg") -- image data as a binary string
body =
table.concat(
"--" .. boundary,
"Content-Type: image/jpeg",
filedata,
"--" .. boundary .. "--",
"\r\n"
resp = {}
local hash = function(...)
return md5sum(table.concat({...}, ":"))
local parse_header = function(header)
local result = {}
for key, value in (header .. ","):gmatch("(%w+)=(.-),") do
if value:sub(1, 1) == '"' then -- strip quotes
result[key:lower()] = value:sub(2, -2)
return result
local make_digest_header = function(headers)
local digest = {}
for _, header in ipairs(headers) do
if not header.unquote then
header[2] = '"' .. header[2] .. '"'
digest[#digest + 1] = header[1] .. "=" .. header[2]
return "Digest " .. table.concat(digest, ", ")
local _request = function(req)
if not req.url then
return nil, "missing url"
local url = skturl.parse(req.url)
local user, password = url.user, url.password
local sink = req.sink
if not user or not password then
return nil, "missing credentials in url"
url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil
req.url = skturl.build(url)
local source
if req.source then
local chunks = {}
local capture = function(chunk)
if chunk then
chunks[#chunks + 1] = chunk
return chunk
local chunk_id = 0
source = function()
chunk_id = chunk_id + 1
return chunks[chunk_id]
req.source = ltn12.source.chain(req.source, capture)
req.sink = nil
local body, code, hdrs = skthttp.request(req)
if code == 401 and hdrs["www-authenticate"] then
local ht = parse_header(hdrs["www-authenticate"])
if not ht.realm or not ht.nonce then
return nil, "missing realm/nonce from response"
local qop = ht.qop
if qop and qop ~= "auth" then
return nil, "unsupported qop " .. tostring(qop)
if ht.algorithm and ht.algorithm:lower() ~= "md5" then
return nil, "unsupported algo " .. tostring(ht.algorithm)
local nc = "00000001"
local cnonce = string.format("%08x", os.time())
local uri = skturl.build({path = url.path, query = url.query})
local method = req.method or "GET"
local response = hash(hash(user, ht.realm, password), ht.nonce, nc, cnonce, "auth", hash(method, uri))
req.headers = req.headers or {}
local auth = {
{"username", user},
{"realm", ht.realm},
{"nonce", ht.nonce},
{"uri", uri},
{"cnonce", cnonce},
{"nc", nc, unquote = true},
{"qop", "auth"},
{"algorithm", "MD5"},
{"response", response}
if ht.opaque then
table.insert(auth, {"opaque", ht.opaque})
req.headers.authorization = make_digest_header(auth)
if not req.headers.cookie and hdrs["set-cookie"] then
-- not really correct but enough for httpbin
local cookie = (hdrs["set-cookie"] .. ";"):match("(.-=.-)[;,]")
if cookie then
req.headers.cookie = "$Version: 0; " .. cookie .. ";"
if req.source then
req.source = source
req.sink = sink
return body, code, hdrs
local request = function(url)
local t = type(url)
if t == "table" then
return _request(table.clone(url))
elseif t == "string" then
local req = {}
local _, code, headers = _request({url = url, sink = ltn12.sink.table(req)})
return table.concat(req), code, headers
request(
method = "PUT",
headers = {
["content-length"] = #body,
["content-type"] = "multipart/form-data; boundary=" .. boundary
elseif fire == false then -- Removes image from intercom
log("Firealarm reset")
local result = {}
return result
local digest = {}
if not req.url then
local source
if req.source then
local chunks = {}
if chunk then
return chunk
local chunk_id = 0
source = function()
req.sink = nil
local qop = ht.qop
local auth = {
{"username", user},
{"uri", uri},
{"cnonce", cnonce},
{"qop", "auth"},
if ht.opaque then
if cookie then
if req.source then
req.source = source
req.sink = sink
local t = type(url)
local req = {}
request {
method = "DELETE",
if code == 200 then
log("Error deleting image: " .. code)
log("ERROR")
