Threads: 13
I want to create a counter for steps so that the shutter will not go up (using only the steps command in the controller), it will only take 7 steps with a value of 1 and 7 with a value of 0. This means that the shutter can only move at angles. Thanks
Can you explain in more detail what do you want to achieve? Do you want a specific object value not to exceed a certain limit?
Threads: 13
Hello
I want a shutter user to not be able to lift it. Just take steps. X steps to open shutter stages. X steps back to close. that the user does not continue to click on steps in the shutter. Best regards
Sorry, it still is not very clear what is needed. Do you want to convert binary object (step up/down) to a scale value (0..100%) with some limits on the output value?
Threads: 13
yes , 7 step up 7 step down ( 1bit)
You can modify the script as needed. You can put any group address there instead of 0/0/2. Binary object is datatype 01. 1 bit (boolean).
+1 / -1 is the step direction. If false is received then current_step = current_step - 1, if true is received then current_step = current_step + 1. Then the current_step value is limited between 0 and 6.
