16.02.2023, 17:16
(This post was last modified: 16.02.2023, 17:43 by bednarekluc.)
Hi there,
I'm looking to convert this python code to LUA.
I have no clue how to start.
Can this be done?
Any help would be greatly appreciated.
The full code is attached to this post.
These are the Classes :
And this Is the code to run the classes :
Can this be done?
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293
# Copyright 2021, 2022 Milan Meulemans.
# This file is part of aioaseko.
# aioaseko is free software: you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# aioaseko is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with aioaseko. If not, see <https://www.gnu.org/licenses/>.
"""aioAseko web API account."""
from __future__ import annotations
from dataclasses import dataclass
from aiohttp import ClientError, ClientResponse, ClientSession
from .exceptions import APIUnavailable, InvalidAuthCredentials
from .unit import Unit
class WebAccount:
"""Aseko web account."""
def __init__(self, session: ClientSession, username: str, password: str) -> None:
"""Init Aseko account."""
self._session = session
self._username = username
self._password = password
async def _request(
self, method: str, path: str, data: dict | None = None
) -> ClientResponse:
"""Make a request to the Aseko web API."""
resp = await self._session.request(
method, f"https://pool.aseko.com/api/{path}", data=data
if resp.status == 401:
raise InvalidAuthCredentials
try:
resp.raise_for_status()
except ClientError:
raise APIUnavailable
return resp
async def login(self) -> AccountInfo:
"""Login to the Aseko web API."""
resp = await self._request(
"post",
"login",
"username": self._username,
"password": self._password,
"agree": "on",
data = await resp.json()
return AccountInfo(data["email"], data["userId"], data.get("language"))
async def get_units(self) -> list[Unit]:
"""Get units."""
resp = await self._request("get", "units")
return [
Unit(
self,
int(item["serialNumber"]),
item["type"],
item.get("name"),
item.get("notes"),
item["timezone"],
item["isOnline"],
item["dateLastData"],
item["hasError"],
for item in data["items"]
@dataclass(frozen=True)
class AccountInfo:
"""Aseko account info."""
email: str
user_id: str
language: str | NoneAnd this Is the code to run the classes :
from aiohttp import ClientSession
from asyncio import run
import aioaseko
async def main():
async with ClientSession() as session:
account = aioaseko.MobileAccount(session, "aioAseko@example.com", "passw0rd")
try:
await account.login()
except aioaseko.InvalidAuthCredentials:
print("The username or password you entered is wrong.")
return
units = await account.get_units()
for unit in units:
print(unit.name)
await unit.get_state()
print(f"Water flow: {unit.water_flow}")
for variable in unit.variables:
print(variable.name, variable.current_value, variable.unit)
await account.logout()
run(main())
