Threads: 1
Hi all, I use Wiser for Knx, and started recently. I have no long or complicated scripts. However, my log fills with logs of script 'script unknown' and message '* string'. How can I find out what is going on?
Erik
Threads: 28
Start by disabling all your scripts and see if it is still happening. Also check common functions if you didn't add anything there.
Threads: 45
Which apps do you have installed?
Threads: 1
I am not sure: I did not install any app, but use Wiser for KNX as is: it was installed and did some basic visualizationstuff. I upgraded to firmware 2.8 Could that cause this?
Threads: 28
Go to app store and update all apps, some are preinstalled by default
Threads: 1
I removed all apps, since I don't use them (maybe later). I also restarted the system, but still the logs remain.
I only found 1 error message: At startup about ModBus: Resident script:118: attempt to perform arithmetic on global 'value' (a nil value). However, this has been there in the past. The tab ModBus is completely empty
Threads: 28
Make a backup and perform factory reset. See if it is still there
Threads: 1
I did this, and my system did not connect anymore. That was fixed by a friend (connection mode was wrong). This did not solve it either. Than I found a modbus connection, which was not useful in my situation. After removing that the issue was solved.
I thank you very much for your help. It taught me a lot about were to look for issues.
