Threads: 20
I would like to create two buttons with wich I can raise or lower the setpoint by 0.5 degrees.
Is there any way beside create a virtual object for every thermostat or a custom script for every button couple?
Threads: 30
In Mosaic or in Visu?
Threads: 30
Then use direct input and set step to 0.5. You can also define min/max
Threads: 20
Yes, it's the first thing I tried, but I would like to create a custom button that only raise setpoint by 0.5 degrees steps and another one that lower without showing the + and - widget.
Is it possible? Am I missing something?
In this case you will need extra group addresses and an event script.
Threads: 20
Ok, thanks for the fast reply.
Perhaps it can be an useful feature to add if you're looking for suggestions.
