Threads: 38
23.11.2016, 07:33
is there a way to set an address group to 1 if there is an error with the modbus communication?
I use the RTU Modbus communication with profiles.
Threads: 43
We have plans to add a status object, but it will work the other way round: 0 = missing, 1 = present/ok. As a work-around you can try monitoring one of the mapped objects last update time to check for failed communication. But this might not work if register value is not changing very often.
Threads: 38
Thanks!
How can I check the last update time of an object with script or javascript?
Threads: 43
Maybe for the next major version, not sure at the moment
