Decimal To Hex
Hi I'm trying to get decimal R,G,B colors and convert to hex with this code
function rgbToHex(r,g,b)   rgb = (r * 0x10000) + (g * 0x100) + b     return string.format("%x", rgb) end
The problem is if i use big numbers then 160 function returns 0.
I think "%x" formatter doesn't format the number but couldn't solve yet
You can do it this way:
function rgbToHex(r,g,b)   return string.format('%02x%02x%02x', r, g, b) end
Your original function should work if color values are in the 0..255 range. But the output value width will vary unless the format is changed to %06x.
