KNX Filtering
Greetings
I have a question about the filter rules in Spacelynk.
Is it not possible to Filter IP>Local and still got the objects in Visu?
My Topology Structure is similiar like this:
I have a Weather Station behind Logic Machine for central Tasks.
But of course all the IP Traffic is to much for TP.
If i activate Filter IP>Local then there is also no traffic from IP "inside" the machine.
I hope it is understandable what I mean Undecided
Local are the telegrams which LM can see, If you block it then no LM will not see them.
You can filter individual telegrams or even simpler a physical address of your weather station.
Ok Thank You.
So LM is not working like a KNX IP Router because there is no Filtering between IP and TP.
It does, page 96
https://openrb.com/wp-content/uploads/20...3.2022.pdf
