Possible, but it depends on several other packages which have to be adapted/compiled for LM. Do you really need XLSX support? There's a specific XML format that Excel understands which can have formulas and formatting. It's not very simple but can be generated without any additional libraries. What kind of data do you want to put in your report?
If you want to test, I can prepare packages by the end of this week. For which LM do you want these packages?
Threads: 161
If this wouldn't be a problem please prepare this for the Load Balancer and LM4. I will check this function and prepare some script with report example. You can add this to the examples on the openrb.com if you want.
Threads: 0
Hello
I currently have a similar problem. The customer would like to receive the data from the trend recording as XLSX format by mail. The automatic mail with the data as CSV format works, but I cannot send the data as XLSX format.
Unfortunately, the links above no longer work....
I have a LogicMachine LM5Lp2 in use
Thanks for the support
What is the hardware model? You can check it in System config > System > Upgrade firmware.
Threads: 11
Hello everyone!
I need to deal with XLS and XLSX files, that's whay I found this post. Is this feature already integrated in the new firmware or these files are still a "must have". In that case, the files are no longer in the server. It's still posible to do it?
thanks!!
