Threads: 21
(08.05.2024, 06:44)davidchispas Wrote: Hello, I can't link the LM bridge with the home app. I scan the QR and after several minutes it mentions that the accessory was not found.
Which firmware and what homekit app version?
Threads: 41
Post what you have in Homekit app logs (click the file icon).
Threads: 41
Nothing relevant in the logs unfortunately. What about LM Error logs?
Threads: 33
I have a question about the functionality of the devices I've set up. It's a very simple installation where I've created controls for lights, exterior door openings, and scene activations.
For lighting, the type of control is clear, using either simple light devices or dimmable ones for adjustable lights. However, I have a problem with the door opening. The device enabled in HomeKit is a scale type, but my control is simple and I've registered it as a simple output device. Similarly, for executing scenes created in LM, I'm using the simple output device.
My client has registered the devices in the Home app and distributed them in different rooms. However, when they send the command to turn on the lights, it triggers everything, including scenes, doors, and lights.
What could I be doing wrong?
Threads: 21
It is hard to say from your description but log all the objects and track where from the trigger is coming from.
