Threads: 16
04.05.2023, 11:19
(This post was last modified: 04.05.2023, 11:20 by a455115.)
Is it possible for a resident script to be executed from a file that is uploaded to a device and not be visible in the window of the LM?
You can use a user library with "Keep source" disabled.
Threads: 16
Can you give me some details?
How do I activate it? Can I change it if I need to?
Sorry for the stupid questions!
Threads: 16
Thank you so much!
Am I to understand that if I have the library saved, make changes and set it to the same name, it will overwrite the original library? Is this code backed up with the project?
Without "Keep source" only the compiled bytecode library is saved. The editor will be empty in this case because the source is not kept. You can put new code there and it will overwrite the current library. The backup will include such library but without the source code of course.
Threads: 16
This is exactly what I needed.
Do I have to write this code (fn = require('user.my_user_library')fn()) in a resident script to call the library?
Threads: 31
An example. I created user library with name 'test'
This is the library:
return function()
log('test')
Each time it is called it will create log 'test'
To cal it create a resident or any other script and use this code.
fn = require('user.test')
fn()
Threads: 16
Thanks a lot, now I understand how it works.
