HTTPS Visualization in Android Touch Panel
I frequently use SpaceLynk with Android Wall Touch Panels with no problems. I use Chrome in fullscreen to display the visualization.
But since the last firmware (2.8) i'm getting a warning that is always present at visualization like in the attached picture.
In the change log for this firmware they included a HTTP warning that should be causing this.
How do I disable this warning or overcome this issue?
To turn HTTP back on go to System config > Services > HTTP server and set HTTP mode to "HTTP and HTTPS enabled". You might need to clear cache on your touch panel if HTTP is still redirecting to HTTPS.
