How to replace?
Hi all,
I'm working on a Vestaboard API integration. And so far everything is working fine but now i want to replace the status (layout) to a readable string so i can use it in my visualization.
The Vestaboard returns the layout like this:
  "currentMessage": {
    "layout": "[[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,8,5,12,12,15,0,23,15,18,12,4,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]]",
    "id": "172c7808-52db-4eb9-9ecf-505bd00436bc"
  And i created a JSON string of all numbers and their corresponding characters:
characters = '{"0":" ","1":"a","2":"b","3":"c","4":"d","5":"e","6":"f","7":"g","8":"h","9":"i","10":"j","11":"k","12":"l","13":"m","14":"n","15":"o","16":"p","17":"q","18":"r","19":"s","20":"t","21":"u","22":"v","23":"w","24":"x","25":"y","26":"z","27":"1","28":"2","29":"3","30":"4","31":"5","32":"6","33":"7","34":"8","35":"9","36":"0","37":"!","38":"@","39":"#","40":"$","41":"(","42":")","44":"-","46":"+","47":"&","48":"=","49":";","50":":","52":"\'","53":"\\"","54":"%","55":",","56":".","59":"/","60":"?","62":"°","63":"red","64":"orange","65":"yellow","66":"green","67":"blue","68":"purple","69":"white","70":"black","71":""}'
So now i need a script that convert the Vestaboard "layout" with the characters string.
Many thanks for your help.
Try this. The example has the layout array encoded as a JSON string for some reason. It might be an error in the documentation. If it's not then uncomment line 42 and remove line 43.
chars =  {
  [0] = " ", [1] = "A", [2] = "B", [3] = "C", [4] = "D", [5] = "E",
  [6] = "F", [7] = "G", [8] = "H", [9] = "I", [10] = "J", [11] = "K",
  [12] = "L", [13] = "M", [14] = "N", [15] = "O", [16] = "P",
  [17] = "Q", [18] = "R", [19] = "S", [20] = "T", [21] = "U",
  [22] = "V", [23] = "W", [24] = "X", [25] = "Y", [26] = "Z",
  [27] = "1", [28] = "2", [29] = "3", [30] = "4", [31] = "5",
  [32] = "6", [33] = "7", [34] = "8", [35] = "9", [36] = "0",
  [37] = "!", [38] = "@", [39] = "#", [40] = "$", [41] = "(",
  [42] = ")", [44] = "-", [46] = "+", [47] = "&", [48] = "=",
  [49] = ";", [50] = ":", [52] = "'", [53] = '"', [54] = "%",
  [55] = ",", [56] = ".", [59] = "/", [60] = "?", [62] = "°",
function decode(input)
  for i, code in ipairs(input) do
    input[ i ] = chars[ code ] or ''
  local res = table.concat(input)
  return res:trim()
data = [[
  "currentMessage": {
    "layout": [
data = json.pdecode(data)
-- messages = json.pdecode(data.currentMessage.layout)
messages = data.currentMessage.layout
for i, message in ipairs(messages) do
  messages[ i ] = decode(message)
log(messages)
Thanks for your help admin. Below the complete script to get the Vestaboard message including the colors regarding their character codes
require('json')
require('ltn12')
require('socket.http')
token = 'YOUR TOKEN'
chars =  {
  [0] = "[ ]", [1] = "A", [2] = "B", [3] = "C", [4] = "D", [5] = "E",
  [63] = "[R]", [64] = "[O]", [65] = "[Y]", [66] = "[G]",[67] = "[B]",
  [68] = "[V]", [69] = "[W]", [70] = "[ ]",[71] = "[ ]"
  return res:trim()
data = {}
res, code = socket.http.request({
  url = 'https://rw.vestaboard.com/',
  method = 'GET',
  headers = {
    ['X-Vestaboard-Read-Write-Key'] = token,
    ['Content-Type'] = 'application/json',
  sink = ltn12.sink.table(data),
if res and code == 200 then
  data = table.concat(data)
  --log(messages)
  log('Vestaboard error', code, table.concat(data))
log(messages)
