LM5 replace ABB IPR/S 3.1.1 issue
Dear admin,
When I try to replace ABB IPR/S 3.1.1 with LM5 using the same parameters.
After replacement, LM5 has no respone to action command from other IP interface.
ABB IPR/S 3.1.1 parameters are as below:
IP address assignment method = Fixed
IP address = 192.168.1.105 Subnet = 255.255.255.0 Gateway = 192.168.1.1
BaseT = 100 MBit/s
Physical address = 1.1.17
Programming mode = Off
Routing multicast = 224.0.23.12
By the way, other IP interface use 2 line address to communicate in KNX system as picture
Is there any suggestion to slove this problem?
I have total 9 ABB IPR/S 3.1.1 modules needs to be replace by LM5.
Thanks a lot.
Drop screenshot from KNX Settings in LM.
During the waiting time, I decided to do factory reset LM5 firstly.
Fortunately, after the reset, problem has been solved.
Anyhow, thanks very much for your reply.
