APM303 modbus communication with wiser fro knx
hi, please i need to read data from APM303 SDMO power generator on wiser but i donc nknow how to make it. i know it is possible to connect slave divice on wiser but i don't know how to perform it, please need you help on how to make it possible.
your sincerely
Modbus is connected via RS485. For communication to work you need to create a profile. Register addresses and formats can be found in the device documentation. See profile examples here: https://forum.logicmachine.net/showthread.php?tid=839
(26.06.2023, 10:05)admin Wrote: Modbus is connected via RS485. For communication to work you need to create a profile. Register addresses and formats can be found in the device documentation. See profile examples here: https://forum.logicmachine.net/showthread.php?tid=839
thanks for ur answer, in my device documentation i have a file call modbus function, now what i want is to know how to get data from specific fonction. i join this  document to this thread
your sincerly
.pdf   APM303 modbus manual.pdf (Size: 3.63 MB / Downloads: 40)
Configure RTU settings so they match your device settings. Then use Read test to check that communication works. You can use Excel profile generator to create JSON profile: https://forum.logicmachine.net/showthread.php?tid=3053
(26.06.2023, 11:08)admin Wrote: Configure RTU settings so they match your device settings. Then use Read test to check that communication works. You can use Excel profile generator to create JSON profile: https://forum.logicmachine.net/showthread.php?tid=3053
hi, i have make json file and i have read the value of battery voltage but i get 120 intead of 12v. i need to know how to solve this
Add "value_multiplier": 0.1 to your profile
(26.06.2023, 09:56)mellotron Wrote: hi, please i need to read data from APM303 SDMO power generator on wiser but i donc nknow how to make it. i know it is possible to connect slave divice on wiser but i don't know how to perform it, please need you help on how to make it possible.
your sincerely
Hello, I need to enable Modbus on the same diesel generator APM303. But I can't read any values from it. Could you help me, have you activated it in some way (software or hardware on the generator itself)? Can you provide me with your profile for the generator for LM?
(04.08.2023, 07:09)Sistema AI Wrote:
(26.06.2023, 09:56)melotrón Wrote: Hola, necesito leer los datos del generador de energía APM303 SDMO de forma más inteligente, pero no sé cómo hacerlo. Sé que es posible conectar un dispositivo esclavo en Wiser, pero no sé cómo hacerlo. Necesito ayuda para hacerlo posible.
tuyo sinceramente
Hola, necesito habilitar Modbus en el mismo generador diesel APM303. Pero no puedo leer ningún valor de él. ¿Podrías ayudarme, lo has activado de alguna manera (software o hardware en el propio generador)? ¿Puede proporcionarme su perfil para el generador de LM?
Hola amigo, también he intentado leer los logs del APM303 sin éxito, ¿pudiste hacerlo?
