SDI-12 communication
Hi All,
Does anyone know if it's possible to integrate a weather station using SDI-12 communication? Also interested if you see any pros or cons. Smile
SDI-12 communication configuration
Baud Rate 1200
Start Bits 1
Data Bits 7 (LSB first)
Parity Bits 1 (even)
Stop Bits 1
Logic Inverted (active low)
Integration guide: http://publications.metergroup.com/Integ...0Guide.pdf
You will need an extra protocol converter hardware, it cannot be connected directly.
(03.07.2023, 14:19)admin Wrote: You will need an extra protocol converter hardware, it cannot be connected directly.
Ok thanks admin.
