"* nil" record in Logs for script unknown
I am having problem with with "* nil" entries into the Logs. Every time any script runs (mostly using event scripts) getting record in Logs with Time, script unknown, * nil. (see in attachement). It does this also for periodically ran scripts too.
If I disable script running the entries in Logs stop. Could you please provide some guidance what to check/fix? Or if I should provide more info, scripts, access...
Thank you,
Pavel
Always start with providing FW version when weird issues are detected  Idea
Sorry, for that. Here is the info.
HW: LM5 Reactor IO V2/V3 (i.MX6)
SW: 20230607
Send me your backup to PM.
You have user library user.blockly with just code:
log(a);
Due to auto load library enabled it runs on every script execution.
(17.07.2023, 12:44)Daniel Wrote: You have user library user.blockly with just code:
log(a);
Daniel, thank you for you help. That was it. Since it was there since import (like 6 years ago) I was not expecting to causing such a trouble.
P.
