wiser for knx authentication
hi, i have make an lp file on wiser for knx and when i try to make an http request to this particular fil using javascript the W4K require authentication please how to avoid this
Where did you upload it?
(17.07.2023, 14:16)Daniel Wrote: Where did you upload it?
on "user" file
Then check the user access settings, you can disable password for user folder.
(18.07.2023, 10:01)Daniel Wrote: Then check the user access settings, you can disable password for user folder.
thank your
