http post/request
I'm trying to sent a command to a homewizzard socket, to put him on and off, but really don't know how to sent the command.
I can read the value's but don;t know to sent it on and off.
hope someone can help me?
this is what i use to read
require('socket.http')
ip = '192.168.99.73'         --Ip adres of the socket
socket.http.TIMEOUT = 5
data = socket.http.request('http://'..ip..'/api/v1/state')
--{"power_on":true,"switch_lock":true,"brightness":0}
if data then
log('HW socket: Televisie: State'..data)
this is what the site said about the command.
Turn on socket
<Request>
PUT http://{IP address}/api/v1/state HTTP/1.1
Content-Type: application/json
Content-Length: <length>
   "power_on": true
<Response>
HTTP/1.1 200 OK
{[url=https://homewizard-energy-api.readthedocs.io/endpoints.html]page of HomeWizzard[/url]
   "power_on": true
what i get when read the url:
P1 HomeWizzard TEST 08.08.2023 12:57:02
* string: HW socket: Televisie: State{"power_on":true,"switch_lock":false,"brightness":0}
Try this:
json = require('json')
http = require('socket.http')
body = json.encode({
  power_on = true
resp, code, hdrs, stat = http.request({
  url = 'http://{IP address}/api/v1/state',
  method = 'PUT',
  headers = {
    ['Content-Type'] = 'application/json',
    ['Content-Length'] = #body,
  body = body
log(resp, code, hdrs, stat)
Thanks a lot, this is working.
