SCENES VS SCRIPTS
Greetings
I need to drive various lights divided into scenes
 with groups and subgroups, I should use scripts to activate or deactivate scenes or compile the scenes with all the addresses to drive, both for switching on and off.
Thanks so much
Both approaches will work. You can trigger scenes from scripts and vice versa. Just make sure you don't create an infinite loop Smile
(06.09.2023, 13:01)admin Wrote: Both approaches will work. You can trigger scenes from scripts and vice versa. Just make sure you don't create an infinite loop Smile
Yes
in fact my fear is precisely that I was trying to create a script that activates or deactivates subgroups of scenes so that it is also convenient for future modification.
Could this be a valid idea?
A thousand thanks
There's a possibility to run multiple scenes from a script by using tags: https://openrb.com/docs/lua.htm#scene.tagrun
