28.09.2023, 16:11
I just publish exchange w Erwin for information
Hi Erwin,
It is possible
- to acknowledge each individually alarm
- to log date/time of the acknowledgement (for one alarm or screen/group of alarms like now)
Best regards
Frederic
Please ask questions on the forum so other forum users can benefit from the answers..
1) No not possible
2) Only when using visu with iframe so you can use custom js like this:
Now you can add an event based script to (in this case) 10/0/0 and create any log you like with LUA
Hi Erwin,
Thanks for your prompt answer
1) I create 2 virtual objects
- 32/1/60 'alarm' with alert LUA event script and log
- 32/1/61 'last acknow' with log
2) I valid the @ip of lm in the google chrome
3) I write your custom js on lm:
$(function(){
$(document).ready(function() {
var f= $('iframe');
f.load(function(){
f.contents().find('#AcknowledgeButton').click(function() {
grp.write('32/1/61', true)
==> and there is no log for 32/1/61
Best regards
Do you have the alert manager in an iframe inside your visu’s plan?
Yes
Do you have selected the box "persistant" on your iframe, otherwise the source is unloaded when not visible and any JS handlers to the source are dropped..
I select the box and now ii's ok
thanks
best regards
Hi Erwin,
It is possible
Best regards
Frederic
1) No not possible
$(function(){
var f= $('iframe');
f.load(function(){
grp.write('10/0/0', true)
Hi Erwin,
$(function(){
var f= $('iframe');
f.load(function(){
Best regards
Yes
thanks
best regards
