Schedule
Good evening, I have a problem with LM schedules. It is a schedule that occurs every day every month at a fixed time. It runs once and then deactivates. It is necessary to reactivate it manually. It's likely that you're doing something wrong. Thank you.
Scheduler has "Scheduler on/off object:" you can use it to enable/disable scheduler.
Can you send a screenshot of the schedule object mapping?
You probably have the enable object mapped to the output object…
Thanks Daniel, Thanks Erwin. Erwin these are the screenshots
Make sure that you don't have the same object mapped to control and on/off:
Thanks, a change I missed
