07.10.2023, 02:20
Hi!
What would be the preferred method of getting data from various IoT sensors (like Raspberry Pi Pico W or ESP32) into Wiser for KNX? I'm open for suggestion both using software only (for example http get or post) or some kind of physical hardware interface that can be attached to a dedicated "IoT importer device" with wired access to Wiser for KNX.
Being most familiar with web development, I am currently using an .lp file in my /user/ catalog on Wiser for KNX that the IoT-devices occasionally request passing sensor readings in the url via get, like "[ip...]/user/import.lp?temperature=20.1&humidity=45". In import.lp I pass the variables on to various group addresses in W4K.
Is this an acceptable solution, or is there a smarter (faster) way that puts minimum stress on the CPU? New data flows in every minute or so.
Thanks!
Robert
Thanks!
Robert
